Hello all,
I have the 2012 Coupe with the Nav and bose audio system. I've read that its possible to use the rear subwoofer as a location to tap into the wires for a line out converter. The converter I am using is the PAC SNI-35 which has wires for a right and left speaker. I have read through the forums and most people seem to get this to work, however when I connected it to just the left speaker wire using the green/black and blue/white plus ground (black), I am not receiving any voltage output at the RCA end. I've tested the speaker wires going into the sub and they both receive about 12VAC. I then hooked up the negative wire for the right speaker on the line out converter to the negative wire of the subwoofer since the directions mentioned that if only one side was available. still nothing. I could use a high output speaker level line and run it into the amp but since I have already bought good RCA wires and this lineout converter I want to still try and make it work since I have read that people were successful. Should I try connecting the positive wire for the right speaker on the converter to the positive on the sub? Maybe my converter was DOA?
