I bought a manual transmission V which already had a tune, cold air intake, and 2.5 inch exhaust and it also came with a light throttle(24%) jerking/bucking, more noticeable going downhill. I swapped in ID1050X, 1 7/8 long tube headers with no cats, a 2.55 pulley, and a AEM wideband. Its temporarily running on a MAF only tune and runs pretty good besides the jerking at light throttle roughly around 24% throttle, doesn't matter what RPM. At first I thought it might have been one of my spark tables, then I noticed its leaning out to 18:1 while this is happening, also noticed the MAF reading is bouncing around a lot while holding steady throttle. I had an issue with the car dying after driving off and going above 2000rpm and realized it was the MAF so I already replaced it with a new OEM, also replaced the o2's when I replaced the exhaust manifolds. I was wondering if anyone has any suggestions, should I try to run both SD tune with MAF? Should I try to replace the cheaper cold air intake? Honey comb before the MAF? Is this abnormal for a MAF only tune? I'm going to attach a HP tuners screen shot while the issue is happening...
Let me know if there's anything else I can contribute to help diagnosis my issue
