1 - 10 of 10 Posts
Hello, everyone. Just wanted to introduce our latest addition to our lineup for the LTX, a much-needed "4th hitter". The result of almost two years of work, built from the ground up to compete and win. Brings a much-needed alternative to a limited, almost monopoly-like, market. Now you can have the best yet you do not have to pay the most.
Introducing Soler Performance 103MM throttle body for all the LTX's engines and more.
  • At 1700+/-50 SCFM @ 20.4" Water, it flows like a 107mm TB but fits like a 103MM.
  • Has all the goodies/features we have seen in our LT1/LT4/LT5, plus some new features, all unique to our throttle bodies.
  • Designed with driveability in mind, it behaves like a stock TB when idling, composed when cruising, responsive when demanded, and a black hole available beyond that.
  • Firm and balanced at WOT under boost and not a nightmare to tune at partial throttle. In fact, runs smoothly even on stock LT1's with the stock tune.
  • Flexible bolt pattern to directly fit all LTX manifolds/superchargers (stock or custom), including the LT5 supercharger.
  • We have also added a set of accessories (customizable if required) to ensure a perfect fit, sealing, and transitions.
  • Made from materials equal or better than those used by the OEM. Fully machined for a better finish and repeatability.
  • It is durable, strong, and stiff for its duty, yet light and stylish for your interior looks.
  • Fully tested and approved by forum members.
  • All this with a warranty, customer service, and technical support to be matched.
151648
151649
151650
151651
Visit https://www.solerengineering.com/generalmotors/se1000-107 for more info.
Thanks,
V Coupe Pedal car
Thanks for posting this! I recently purchased your 90mm unit though I've not installed it just yet. Once I get the next round of mods done, I may be ready for this one.
Reactions: [email protected]
I see the shaft is dimpled, is that to improve flow?
V Coupe Pedal car
I’ll assume that’s what they’re for, makes sense. But I just saw that the one I bought doesn’t have the dimples! I’m so jealous now!
I wonder if I can send it for a dimple retrofit...
Reactions: WaitedTooLong4MyV
The blade and the port doesn't look like a normal Soler TB, why not?
2009 Sedan
Hi, loweredd. Would you rephrase your question?
Thanks,
The SE5109-95 for LS3/LS7 gold blade says for N/A.
V Coupe Pedal car
This part number was used by GM in naturally aspirated applications. It can be used on blown motors, no problem, but its original uses were N.A.
This is the unit I bought.
Reactions: loweredd
V Coupe Pedal car
  • Thanks,
  • Do you offer a 100mm + for the LSA V2 ?
    I have your 90/95 but I changed my build and can predict that I’ll likely need a 102 or similar. Tell me what you have for this?
1 - 10 of 10 Posts
