The scenario was likely the following: 1, pump motor bearings went bad, caused a drag on the motor, motor overheated, pulled high current (but not enough to blow the fuse) for a while and severely melted the wiring.
2. Eventually the motor locked up due to bearing failure; at this point the amps became extreme enough to blow the fuse.
3. Fuse replaced... cooled motor runs for a short time but of course, later locks up, cooks the wires some more, then blows the fuse.
4. Fuse replaced (likely with higher-rated fuse) and cycle repeats: heat/cook wires/lockup/blow fuse.
5. pump motor gets replaced; wires not addressed
6. pump is getting low voltage due to roasted wires/ bad connections/melted relay contacts/ corroded connections
7. toasted wires and relay overheat again, blowing fuse.
guess what step 8 is .
