1 - 8 of 8 Posts
Whats the best set up or options for reading IAT1 and 2? I looked around and basically looks like the aeroforce gauge is the option to go with?? If so, what else if anything is needed for that setup?
I have the DashLogic unit that plugs into the OBDII port. The info is displayed in the message center in the gauge cluster.
Reactions: Karch
Is the aero set up plug and play? Anything needed besides a pod to mount it if I don't put it where the clock goes?
Plug and play, just goes into obd2 with supplied harness
Reactions: RedTXV
Dashlogic here as well. Also provides ethanol %
Does the Dashlogic have any logging capability?
1 - 8 of 8 Posts
