1 - 9 of 9 Posts
It is plugged into the cigarette lighter. I noticed when the car door opens, the lighter plug looses it power, how do I wire it into a feed that is always live. The camera will record if someone hits the car but not if it looses power.
You may have to run a wire (with an in-line fuse) from the battery. I can't think of anything inside the passenger compartment that needs to have live power after accessory power shuts off.
There are a couple places to hardwire it, with permanent power.
Here are a couple good threads:
Open the drivers door, pull the triangular cover from the end of the dash and look for a pink wire. Tap into it.
1 - 9 of 9 Posts
