I dont know what to do... I sealed the other side (driver) from the top by sliding the rear glass forward. Then I adjusted the height of both glass pieces so they would seal against the body better. Tried spraying it with the hose (headliner still down), and for the first 30 seconds it seemed fine. Then the passenger rear side, just got over run with water and spilled into the back seat... all 4 drains are flowing... they just cant
I dont know what to do... I sealed the other side (driver) from the top by sliding the rear glass forward. Then I adjusted the height of both glass pieces so they would seal against the body better. Tried spraying it with the hose (headliner still down), and for the first 30 seconds it seemed fine. Then the passenger rear side, just got over run with water and spilled into the back seat... all 4 drains are flowing... they just cant keep up with the amount of water getting past the seal seams. I guess I'll order new glass seals.
It seems this is a very common problem. Does anyone have a permanent fix?
Can someone post the TSB?
Should I be looking to buy parts 2 and 4?
[/QUO
