41 - 60 of 102 Posts
2X 9 second club
2X 9 second club
Yes, and Ronald Reagan was in the White House, and Miami vice was on tv.
Acted like it couldn't spin the tires if it was on wet grass. As it was my first time out with this car I left it in Drive, Sport Mode.
OP says "Drive" and "Sport" but nothing about Traction Control. What does Traction Control do? It keeps the tires from spinning. What was the OP's complaint? The car acted like it couldn't spin the tires on wet grass. I think the answer to his problem has less to do with IATs or how he's launching than it has to do with not turning Traction Control off.
No matter how bad your IATs, the car will still happily spin the tires on a hard launch. It could do that with half the torque it makes when cool.
Try again. But this time turn Traction Control off. And if you haven't been driving with Traction Control off at all, be prepared for a *pissload* of wheelspin.
Discussion Starter #47
Traction control was off. No wheel spin.
Completely off like you held it until it turned TC and Stabilitrak off? Or just one push?
Based on your DA, I don't think you're far off. For comparison's sake, pay attention to what other cars are running and how far off of their advertised times they are. I think that you'll find that you're more in line than you expect. Your state gets legal marijuana. The tradeoff is horrid air for making power.
Discussion Starter #51
Naah, thanks anyway but by any measure, no matter how much I rationalize, this car is just slower than it should be- by several tenths. Still a great car, just not a competitive track car. There are several Vs running up here and although they're faster than mine, they do seem to have trouble repeating consistently.
The long push additionally disables stability control. Traction control is either on or off; there's no middle ground.
DA is a power killer for sure!! Were I race, the DA is usually around 6000 to 7000+. Maybe a pre and post methanol kit would help with the iat2 problem, but that would also mean you would need a tune for it.
Nope, use a DA calculator. I just did and received results between 12.38 and 12.69 at sea level trapping between 117 and 120 mph. Couple that with presumably high IAT2 temps and you have a recipe for high 13-second passes at 8800 feet.
Discussion Starter #55
You might be right zilla, but I'm skeptical. Tell you what, just out of curiosity I'll run this car one day soon under optimum conditions as much as I can and we'll see how much difference IATs make on this particular car.
Come to think of it, I don't see many blower cars getting past the first round in bracket racing.
BTW I use a DA calculator and a race computer on every pass.
See post #3
This was with my car 100% stock.
http://www.ctsvowners.com/forum/148-build-threads/53938-2009-gray-v-sedan.html#post989209. <<link
I dunno...thats a pretty wild and crazy theory...
There is NO WAY high intake temps and high DA will make supercharged car slow! There is just no science to support that controversial idea.
I bet you 100 doll hairs that lower IAT's make your car slower.
Something is definitely wrong with your car, you should probably do a supercharger delete to get more consistent passes for bracket racing.
I get bracket racing, but doing it in a boosted car, especially with A to W cooler, is tough.
[email protected]
Dynamicflowconcepts.net
Nearly 500 passes this ZL1 is consistent enough to win in Pro and King Street and he has data for every single run the car has ever done."
Crewchief Pro Software
You should have been the second post!
[email protected]
