accuracy of the data all starts with the injectors data if that is correct and fueling is correct and fuel pressure is compensated for then it will be as close as it can be, if any of those are out then it goes out down the line with fueling tables n such but small amounts will just be absorbed and not noticed as most if not all would be 100% accurate, log dynamic airflow and maf airflow and VE airflow all in g/s and put them together in the chart v time with same min/max settings and see where they all follow, the dynamic airflow is the final product thats used, when i was on 14psi i was about the 1.8g - 1.9g if i can remember and airflow was in the 750 g/s range i think but i was revving to 6700rpm on ethanol
