1 - 3 of 3 Posts
I broke down a while back and got HP Tuners.
With the assistance of @random84 I turned off the FPMC p0231. To do so, I used credits I had bought.
Well after doing so, the Scanner (the lightning bolt icon) isn't displaying any engine data as it is running.
I've double checked the plug (and the corrections table is reading the car fine).
What should I check to see what I fucked up?
Do you have a configuration file created for the scanner?
Since I don't know what that is....I'd say no.
Before I applied the credits to adjust the p0231, it would read. I could then select scan (the red disk) and start recording....then stop data logging (the square) and the display was still showing RPMs and all that jazz.
Now it only does that when I start logging.
1 - 3 of 3 Posts
