1 - 20 of 25 Posts
09 Ctsv auto trans. Car has a freshly rebuilt lsa shortblock , TSP ported heads BTR stage 3 pds cam, ported blower and snout, 2” headers and catless 3” xpipe to magnaflow mufflers, 2.5 upper and 9.1 lower, track attack HX, varimax pump, and fasterproms icebox, ported ls7 TB, 4” new era intake with the 14” green filter, 1000cc injectors, DW 340lph fuel pumps and a flex fuel sensor. Car is hitting the dyno soon, how much WHP should I expect? Thanks
Reactions: MYV and Blades1_99
Just shy of a million. :)
120 less than you hoped for
648
Reactions: MYV
Tree Fiddy Herspers
Car made 640whp on 93 first pull on the dyno then threw a rod on deceleration.
Faaaaaak! I guess you'll be having a long conversation with your engine rebuilder.
Big OOOF. Good luck. I feel like every situation I have heard or seen like this the engine builder blames the tuner and the tuner blames the builder.
It makes it a lot easier when the same shop builds and tunes it.
Damnitboy........
Reactions: Omgctsv
That’s the beauty of some of the tuners.
The tune it to the ragged edge and then get to build it. It’s a great business model.
The key is to con, I mean win, the trust of the owner of the car.
Discussion Starter · #16 ·
Haven’t torn into yet but there’s a decent hole next to cylinder 2 and pieces of metal that came out. Tuner thinks ring gap was too tight causing the top of the piston to break off or engine builder left a rod cap loose. Talked to engine builder and he’s shocked that this happened. He said to pull the engine and tear it down with him to see what went wrong.
It broke. That's what went wrong. Tell him to build another one while he's waiting for the autopsy results.
Reactions: Prime Time
Discussion Starter · #18 ·
I’ll call him tomorrow and ask if he can start assembling a new engine. Do you think he’ll actually cover the cost?
Doubt it. That doesn’t fit with most business models.
I'd have it out and at his front door in the morning and let him open it up to find out what happened.
Reactions: Omgctsv
1 - 20 of 25 Posts
