How much metal is ok in your engine oil?
3030 Views 27 Replies 12 Participants Last post by  Spearfishin
Noticed some metal on magnetic drain plug, so cut filter open. Hard to catch pictures of it, but there's silver glitter present. Not piles and piles, but not just one or two pieces either. ETA: The metal in the filter pleats appears to be primarily/all non-ferrous.
And there's at least the one "big" piece. Engine has good oil pressure and seems to have normal power. Does (and has since I've owned it) have what I think qualifies as a noisy lifter. Cam/lifters were replaced under warranty at 40k-ish, car has 93k now.
Two questions:
1.) Obviously something is going on. Worth guessing at "what" or motor needs to come out no matter what? (Edit to add): specifically if the assumption is failed lifter or rocker/trunnion, still need to at least check/replace bearings on bottom end, or could I get away with pulling heads in the car and just replacing lifters/cam?
2.) (And I know the answer) I have a track weekend at VIR coming up in two weeks, it's too late for a full refund and I've put a pretty substantial effort into car prep (time and money). There's no chance it's an acceptable idea to act like I didn't change the oil in anticipation, and didn't notice the metal, and didn't cut the filter open, and instead just send it for (8) 20min sessions on a road course?
Wood Stairs Flooring Floor Hardwood
Wood Rectangle Flooring Floor Font
Wood Font Tints and shades Art Artifact
Wood Flooring Road surface Floor Asphalt
Brown Black Wood Textile Sleeve
5
1 - 20 of 28 Posts
If it were mine, I'd pull the engine and find the cause before something goes terribly wrong and costs thousands more to fix.
Reactions: 5
Generally, the answer to that question is "zero".
Reactions: 5
Scored a couple of cylinders on LS3 that ate a lifter. I know where this heads...just don't like it.
Ha, yep! Thread title was a bit tongue in cheek...but I am curious if there's any half steps that are worthwhile vs yanking whole motor.
Id say if you have to ask it is too much
Reactions: 3
Any speculation on what's shedding metal? Seems I had ferrous pieces on drain plug and mostly aluminum in filter.
And follow-on, I have no lofty power goals, so any reason not to just rebuild what I've got with stock/close to stock and perhaps little more cam/head work?
The engine is mostly aluminum but aren't the bearings ferrous? Glitter is one thing, but you have small chunks of metal. I would not run that car at a track event. Right now you could be looking at a pricey rebuild but if you send a rod thru the block the sky is the limit. Also if I was at that event I would be pissed when you spray fluids all over the track from blowing up an engine you knew was on the way out.
Reactions: 2
Yeah I wouldn't just pretend you didn't see the metal and try to run it. You MIGHT make it through the track day but it will absolutely do wayyy more damage and end up way more expensive than if you figure it out and fix it now.
An ounce of prevention is worth a pound of cure.
In this case you are trying to prevent outright block/crank/rods/pistons/heads destruction instead of maybe just needing a minor bearing/lifter rebuild.
Reactions: 2
I know, I know.
I just don't want to miss it. But seems like I'm going to.
Reactions: 2
Pulling the engine and tearing it down is pretty easy. You'll find the issue, get it fixed and sleep better!
Just make sure to follow up to let the group know what you found.
Reactions: 2
I know, I know.
Can you rent or borrow another car? Even driving a slow ass miata on track is fucking fun and you would be surprised who you can keep up with in a "slow" car if you are a good driver.
Buddy has a track prepped Mustang, but he said "nah" and my best friend has a Camaro SS that's in body shop and may or may not be out. He said I can run that if it's out, but I'd need to put pads in it, swap tires on (he's got a set of 200tw in his garage), try to get a more aggressive alignment, etc. etc. etc. and I just don't see that happening since it's in body shop for at least rest of this week.
Other option is I have an inherited 2005 Impreza (naturally aspirated/base model) that's just sitting in my driveway. It's a 5spd, could be fun with sticky rubber and better brakes, but I worry about how soft the stock suspension is.
Safe option is bail, eat the $100 cancellation fee and fix my car before next opportunity to get on track, I think.
Reactions: 2
It's running fine, so I doubt all that metal is from a main/journal. You say it has a noisy lifter. That might be chewing up a cam lobe. Removing the rocker covers is a lot less work than pulling the motor. I'd do that, first.
I wouldn't track it without at least understanding it. Based on what you say about how it runs, I could understand why you might think it's not a huge risk. Except: Murphy.
Reactions: 3
I think tracking as-is is firmly out of the question. I've burned most of my allowed shop time and then some with what I've been doing to the car thus far to get ready, so even top end work done with engine in the car is a bridge too far in the next two weeks.
He’s right! The same thing happened to me during some dyno tuning last January. A lifter collapsed and during the troubleshooting we decided to send the oil to blackstone and it showed excessive wear mostly from the bearings.
Luckily for me the block, heads, crank and rods were in really good shape and the wiseco pistons were good enough to be reused, but we decided to swap those out for the more robust Diamond S2K option. The main work needed was new looser bearings. The bearings were apparently built with to tight clearances for the stress the motor was under, so it was determined by the engine builder to do it his way. Furthermore, the block was cleaned and re-honed for the new pistons and I got all new lifters and a new oil pump because it was unsure if metal got in these parts and we did not want to send metal through a refreshed engine.
This repair set me back about 7.5k (not cheap) for the tear down and parts and labor, but it could have been a lot worse if we carried on and not address the issue.
More than likely this is the route you will likely have to go in a best case scenario if you stop now. As a first step you should send the oil out for analysis and that will give you clearer idea of your engine health before removing the engine.
Reactions: 2
I've never found a great guide to reading oil filters. O had specs of glitter in my old LSA, but the oil analysis was always excellent. Each oil.change for thousands of miles it would stay similar in presentation: specs in the filter but great oil analysis.
I eventually sold it off but never had an issue over... 80k miles? Cam, everything looked good when I pulled it out. So engines do wear. Just like differentials - you're going to get some bits on the magnet and in the filter.
But what concerns me the most are the larger chunks. That seems more ominous. But none of us can tell you what the problem is - only that there might be a problem.
My buddy (full-time mechanic) told me he's convinced filters come new with a little metal in them.
Then he winked, patted me on the ass, and walked off... So I dunno.
  • Haha
Reactions: 2
Sometime in the next few weeks, after my lift goes from "two hunks of steel laying on their side in my shop" to "a functional two post lift", I'll set to work on a diagnostic path.
Any guidance on what that might look like? To my way of thinking, motor should probably just come on out. Even if I found a smoking gun lifter, for example, wouldn't I be best served to go ahead check the rest of the motor? Taking that assumption (that motor is coming out) a step further:
What parts need to be upgraded assuming I don't desire to go much down the rabbit hole of modifying. Or said another way, what parts would I be stupid not to upgrade while motor is out, even if they're upgraded well beyond what's required at stock power levels? Car may end up getting thrown around a road course a few times a year, otherwise just a weekend toy. Will probably look at a mild cam if mine is screwed, lifters/pushrods/valve springs/etc that come along with a "proper" cam swap, but lets say there's no evidence that I have any issues beyond that, can I just leave bottom end buttoned up? If so, back to my first question: Do I really need to pull the motor? Or can I perhaps get away with pulling heads, visually inspecting cylinder walls, etc.?
I'm torn on what to do next, in case my rambling doesn't convey that. I'm also in mourning. This discovery led to a cancelled weekend at VIR, and an added budget line-item that I'm not thrilled about and the wife is really not thrilled about.
I'm not nearly the expert as others here, but I would pull the spark plugs first and use a $20 bore scope off Amazon to look for any obvious damage to pistons or cylinder wall scoring.
Then, if that looks good in each cylinder, I'd pull the blower, valley cover and rocker arms: you'll be able to see some of the cam lobes that way and inspect the valves / springs / retainers for any obvious damage or broken parts. Again, use the bore scope and/or a flashlight to make sure every cam lobe is healthy, less you have a collapsed lifter. You could also check lash on each valve while you're here to again look for any excessive lash (wiggly rocker arm) that might suggest a failed lifter.
If that all looks amazing, I might just put it back together. :D
But if you're really a glutton for punishment, the next step would be to pull the motor, drop the oil pan and then start checking the mains for abnormal wear: I'd pull the #1 main cap and if it isn't absolutely destroyed (think pot-holes on a road), I'd retorque it and again probably just put everything back together. :D
If the main looks really ugly, then start planning your rebuild. Generally, you'll need to deck / hone the block, finish hone the cylinders, clean the block, replace all main, rod and cam bearings, and deck the heads. You'll naturally want to have the valve seats redressed and replace or upgrade the valves, springs and retainers. I think that's the bare minimum.
But "while you're in there..." and don't forget changing higher mile engine accessories (water pump, etc) while everything is out. And...
Reactions: 2
I have a list of all the parts you need, already collated.
Just click my sig line,,,
  • Haha
Reactions: 5
1 - 20 of 28 Posts
