I tried searching, but get a lot of For Sale ads, and I dont want to get banned again for being in the classified. SMFH.
My V is on its way here from Texas and I know it has an upgraded HX and a small under hood ice tank. I just dont understand how the system works I guess. If you fill the ice tank with ice, and that eventually melts, wont you need to drain some water to refill it again later? So that would make me think this water does not mix with the coolant system, right?
Secondly, does the HX have coolant in it? and does that mix with the coolant from the engine/radiator, or are the two systems separate?
I've built several (and bought) LS motors, but this is my first LSA. Its obvious that heat is the enemy and I will be closely watching iat.iat2 temps but need to know how the systems work.
Thanks
PFA
I found the answer on the ZL1 forums. In Florida, where it never gets cold, it seems its best to use just straight distilled water in the HX system/ice box. Which I now know is separate from the engine cooling system. Correct me if I am wrong please.
Thanks
PFA
