Pull the valve covers and look for a broken spring.
Yes.The LS3 from the Corvette's post mortem diagnosis was indeed that lifter had probably rotated in it's bore. That was stock cam (at that point) and so is this. So is it just luck of the draw on which LS's are going to crunch a lifter?
Go back a few years, when a certain popular camshaft grinding companyYes.
It's common enough that people think of it as a 'known issue' but in reality, it's probably not statistically significant given the millions of LS-es out there and the billions of miles driven without lifter issues.
I recently pulled a set from a 140k-mile LSA that appear to be in perfect condition. They might be good for a bunch more miles... but I know that there's no way that I would reuse them!
First, proving the need for lifters (or diagnosing the noise) starts with visual inspection under the valve covers to search for clues you can see and test; spring/rocker/trunnion,pivot,bolt issues and evident lash issues. If ALL of those check out (and if external possibilities are eliminated especially exhaust leaks) and no cause is found by that point, the only what to verify the lifters’ condition is to pull the heads.Help me understand though: where's the root cause in a stock LS lifter/cam failure? Like I say, this car has a factory warrantied cam and lifters installed at 40k miles and is clicking and ticking like it might need something again. My Corvette didn't get past 80k and one of my best friends 6.2 Suburban ate a lifter at 35k.
I know these are anecdotal, and outliers (acknowledging Mr. Surly's correct assertion that there are a lot of them on the road, covering a lot of trouble free miles). I still would like to understand the failure point.
Also, deviated a bit from my original intention/question. Is there a way to validate the need for new lifters (and thus a cam and head work...Because in for a penny...)?
Thanks!
Without meaning to sound short or rude. . .Help me understand though: where's the root cause in a stock LS lifter/cam failure? Like I say, this car has a factory warrantied cam and lifters installed at 40k miles and is clicking and ticking like it might need something again. My Corvette didn't get past 80k and one of my best friends 6.2 Suburban ate a lifter at 35k.
Thanks!
