1 - 10 of 10 Posts
Hey guys.. Got my new drags put on few mins ago. Are these gonna rub? Lol
305/45/17s? Just looks so close and worried when I floor it! Fronts are 26x6x18s
150606
Yours looks to be stock height. If so, they might barely rub the fender on a hard bump. Mine always did it on one side, but never bad enough to cut the tire or do any damage to a fender.
Definitely stock height.... Was more concerned when I floor it. But everyone on here says that's the best tire just didn't know if I was missing something
Stock height should be okay, I had the same situation and instead of testing it out I went with a smaller M&H tire but most say there's no issue to slight rubbing
Reactions: SaskV
Ok. Well I'm going to try it and see what happens. I wonder if new rear shocks would help or not.
I run the same wheel and tire setup on my stock height 2010.
I rolled the rear fenders after I saw a tiny rub on the top outside of the driver's side wheel well. Haven't had a problem since.
Reactions: db-guru
I originally picked up a pair of 305/45/17 M/T's but upon mock up, I elected not to mount them because they appeared to be a very close fit and I didn't want to deal with any issues. Sold them and got the M&H's instead. Fitment for your reference, stock ride height.
150611
Discussion Starter · #8 ·
You get them rolled at a body shop or it something you can attempt yourself?
You should be fine at stock height, although that concerns me since I'm lowered and getting that same size. Coupes have more clearance though, correct?
2014 CTS-V Sedan A6
Buy the base model CTS springs. You'll get the clearance you need for that tire size.
Reactions: Teh V
1 - 10 of 10 Posts
