1 - 20 of 43 Posts
A couple months ago I became a Cadillac owner for the first time. First time having a supercharged V8 as well and you already know it's a monster. This car is my daily driver and I do rack up a ton of highway miles. I'm looking to do the following mods but would like to know the affects it would take on my car, in my situation, before I do. planning to hold on to this car for a long time
2.4 pulley, solid isolator, CAI, ID850 injectors, 160 degree thermostat, HX, high flow pump for the HX, and obviously a tune to top it off.
What can I expect after those upgrades? Bad idea? Better suggestions for a DD? Please let me know
Thanks
2013 CTS V - completely stock
30K miles
That's a great mod plan. I'm happy to see you included a HX off the bat. You'll have plenty of fun with that setup. A good tune will make it drive like stock.
That will be a nice first round of mods, you should see around 550rwhp give or take.
Reactions: Cadi_smurf
That's pretty much the same as my plans for my DD plus plugs. I'm going with either a 2.45 or 2.55 griptec pulley and I'm considering adding headers.
That's a good DD plan. Car will drive like stock but rip when you get on it.
All that will do is get you hooked on the power and make you crave more.
I'd say skip the ID850's, buy ID1000's and a flexfuel sensor so when you want to cruise or travel and get good gas mileage you can run 93 and then when you wanna go fast pump in some E85.
Reactions: 12CoupeV
My research so far says the OEM cats won't last with a 2.4, so the cats need to be gutted or replaced with test pipes or headers. Accurate?
Could also save some coin and go with fic injectors instead of id.
This. Unless your tuner for some reason will only tune ID's. Don't be surprised if they happen to conveniently be an ID dealer.
Reactions: Wrecked Em
Your mod list is pretty spot on for a DD drive-ability a lot of the that is dependent on your tuner.
I hope I'm not hijacking, but with those mods, are headers pretty much a must-do?
Not at all. Minimal gain from headers until you change cam and really start adding power.
They don't hurt, but I personally wouldn't bother until you go over 600 rwhp on gasoline.
[email protected]
Dynamicflowconcepts.net
I ran a 2.4 for almost a year without damaging my cats. Blew the motor, but the cats still looked good LOL.
100 hp gain is very safe IF the tune is good.
[email protected]
Have to add:
Don't go 6th to 3rd in one move with the automatic under full power...that's how the break.
Very stout if that's not done.
Thanks
30K miles[/QUOTE
I have same mod but I added E85 also and I'm @ 595/576 on a 15 V coupe
1 - 20 of 43 Posts
