The name of the sensor that’s cracked and is that the vacuum hoes that’s melted not sure??
Yea second video is coolant lines. Same one popped for me but not that bad. The quick connect broke. I saw online after I replaced the entire hose setup that you can find just the fitting if you look hard enough. Way cheaper if your hoses are ok otherwiseThe name of the sensor that’s cracked and is that the vacuum hoes that’s melted not sure??
1. Boost SolenoidThe name of the sensor that’s cracked and is that the vacuum hoes that’s melted not sure??
