1 - 20 of 25 Posts
So my 2011 CTS-V build is pretty much complete, for now! But I mounted the Fabtech heat exchanger and haven't connected the hoses yet. I don't want to connect the hoses wrong. I was wondering if anyone had a diagram of how the hoses connect to the pump and exchanger. I'm running the Fabtech exchanger with the the CWA-100 pump.
I seen some diagrams online, but not with this heat exchanger. Like how do I tell which port is the inlet and outlet?
I'd appreciate anyone's assistance!
This is what he sent me when I asked the same question.
Ah okay, very helpful! Thanks so much! Do you by any chance know how much coolant this exchanger holds? Or how much the whole system holds? And was it hard to bleed, thats the next thing I have to figure out how to do correctly!
OE quantities are .8gal for the HX, so more than that. Keep filling until she squirts.
.8 gal or 8 gal? 8 gal seems like a lot! I was thinking the whole system prob like 3 gallons or something... And do you have any links to vids on how to bleed the heat exchanger? And do I bleed the heat and exchanger and radiator seperately correct? Prob a dumb question because I'm pretty sure I know the answer....
I really appreciate the feedback!
The heat exchanger and radiator are separate systems.
Bottom of tank to pump, to HX, to bottom brick, back to tank.
Reactions: Copacetic112
If you want pictures, picture 1 is the way to go.
Fill it until it cant take any more. Before driving it, Make sure the pump is on and not hydro locked. (Mine was hydro locked so I kept squeezing the hose from the T to the lid and I could hear and see bubbles coming up out of the T, it eventually turned on) Drive it around for a little while, and add as needed. I had to add to mine about three times. I gave it a few days of driving and checked it again, I had to add a little.
If you have a engine bay icebox, Just fill it all the way up and keep adding until it reaches the icebox lid.
If you had a tank in the trunk, it would fill before the HX and brick is topped off because they are higher. I was thinking about bying a in trunk tank but not sure if it worth the money and time. Has to be noisey in the rear off the car.
Discussion Starter · #12 ·
Well I don’t have a tank yet, prob should. Thanks so much!
Discussion Starter · #13 ·
Don’t have an ice box in engine bay yet prob should get one eventually.
These are my current mods:
  • Forged pistons
  • Forged rods
  • Stock crank
  • BTR stage 2 cam
  • Speed engineering headers
  • Removed the cats
  • 2.55" upper pulley
  • 9.55" lower with balancer w/ green belt
  • K&N cold air intake
  • ARP Head studs
  • Melling 10355HV High Volume oil pump
  • ID 1050x injectors
  • DSX Auxiliary Pump Fuel System 09-15 CTS-V
  • E85 flex fuel
  • NGK TR7IX
  • Reinforced Intercooler 'Brick’
  • Might Mouse Wild catch can
  • 160 Degree Thermostat
  • Fabtech heat exchanger
  • Pierburg CWA-100 (intercooler pump)
Discussion Starter · #14 ·
Okay so I’m gonna prob go with either of these two with distilled water. Anyone have an opinion on which is better? As you can see I really am putting a lot of thought into all this haha Just don’t want to have to rebuild again!
152015
2009 Sedan
I've seen people say use a different color than what is in the engine to help troubleshooting if one or the other leaks.
Discussion Starter · #16 ·
Ya know what, that’s a great idea! Lol
So dex with the Hx and regular Prestige for radiator. How’s that sound? 😁
If you don't have to worry about freezing temps, run distilled in the HX loop.
Discussion Starter · #19 ·
I was thinking of doing maybe like a 75% water/ 25% coolant. I split my time between NY and FL. It’s annoying not knowing the actual capacity of both so I could do exact percentages haha
You would need 3.4gal for the engine coolant, and you'll probably be around 1gal for the intercooler loop with an aftermarket unit in place.....and that would be without an ice tank of course.
1 - 20 of 25 Posts
