I would be lying if I can adequately describe but it was regarding the Jokerz porting and the runners of the Brodix matching up for max flow.
Kong might be different.
I think what Blades was speaking about is simple gasket matching.
I will include an applicable video below.
Most cylinder heads carry with them the size of the valve, as well as the
volume of the runners, which is given in CC's within their tech specs.
In my opinion, if you replace the cylinder heads, it's best to at least
check the intake manifold to cylinder head ports matching.
However, in many cases today, just knowing the volume of the runners
is not going to suffice, even if the intake to cylinder head retaining devices
that clamp the cylinder head to the intake manifold are located in exactly
the same location as with the factory heads.
Why?
Because even if the volume of the runner is the same, the runner inlet
side might have been moved. Again, the clamping devices, mostly just
a simple cap screw, are in the same place, but the inlet runner has been
moved a bit to aid in better flow.
So in Blades case, since JokerZ apparently removed material on the outlet
side of the intake manifold, it most likely has been enlarged just a bit.
If the outlet of the intake manifold is larger than the inlet of the cylinder head,
then nothing would be obstructing the inlet side of the cylinder head, assuming
the bolt locations that fasten the heads to the intake manifold have not been
changed.
Now, I have gone on record as stating I won't use a BR-3 Brodix head.
So I don't know if the port has been moved on the Brodix Head?
I don't like their combustion chamber design!
I much prefer the Mast Combustion Chambers!
Initially I like the CNC Chamber on the new Dart Heads,
but have not been involved with an engine project to
date using that head.
Evidently Tony feels that since the manifold has been ported,which
is an overkill statement for opening up the inlet side of the cylinder
head runner, he might know something I don't?
In any event; most engine builders would desire to know the answer to
that question, and would proceed to gasket match the cylinder head
to intake manifold, at their gasket surfaces, even if the manufacturer
told them the port entry had not been changed.
Since many hobbyists don't know the above, I believe Tony would, and
he simply stated what would be the easiest thing to do in this circumstance.
Blades is very good at what he does, but as he states; he is not an
performance engine builder, he is simply a 'Hot Shoe'..lol
In the end, Blades got a very good head, that not only flows well on the bench,
but when paired with the proper camshaft, also runs well down the track well.
Now, I know what Blades heads flow, does anyone have the flow numbers
for the LME heads?
Here is a link to a good video, just a little over 5-Minutes Long
regarding gasket matching.
Below is the combustion chamber of the Dart Pro LS3 Head.
Here, the criteria is that the valve will be of equal distance
from the combustion chamber wall, as the valve is lifted.
If the above criteria is held, then the Discharge Coefficient
of the cylinder heads flow, at any lift is maintained.
-below-
Versus the 'Crappy' laid back chamber of the stock LS3 / LSA Head.
With this design, the valve opens and enters a more or less flat
combustion chamber, which causes much turbulence.
When turbulence occurs, the Discharge Coefficient goes to Hell,
along with your HP.
Secondly; per Bernoulli; when velocity goes 'Down', pressure, or opposing
pressure in this case, goes 'UP'. Yes, they are inversely related!
The exchange for one, gives the other. . . .
It becomes very difficult to fill a cylinder with opposing pressure!
Bernoulli is a little difficult to understand.
It can take much time. . .
But understanding the teachings of Bernoulli, answers many
of the questions one has regarding cylinder head flow, as well
as cylinder filling.
There are other disciplines that are also important, but Bernoulli
is a good place to start..😊
Cheers,
RD
