1 - 13 of 13 Posts
Passenger side has the tensioner and pretty sure some of the water pump upper bolts attached to it.
Reactions: Bigwilly1267
If you are removing and installing heads, I would love to know how difficult it is once you do it. I am consideting removing mine for porting.
As long as my schedule stays clear I'm doing my heads cam next weekend. I was thinking about documenting some of it since I haven't seen a v specific diy, not that it's much different from the ls3 camaro thread everyone uses and pieces together with the blower removal... But I thought it'd be nice to have something all inclusive in one spot.
Removing heads are easy, but the challenging part is reinstalling with torque-to-yield (TTY) bolts. When I did the heads on an LS3 C6 the TTY bolts required 22 ft-lb, then 90*, then 70* in sequence. It's tedious and helps to have another set of hands. My recommendation would be to torque them all in sequence to 22 ft-lb (assuming our heads are the same as LS3), then mark each bolt and head at 90*, then 70* from there. That would be much easier than using an angle gauge like I did. Better yet, fork over the money for ARP studs and go to town.
I've added LS3 torque specs in case they're of use to anybody.
I vote for you doing a full DIY. I read through that Camaro thread as well and it was useful, but it would be great to get one for our cars. I was planning on doing a DIY when I do mine, but it's better for me if you bust your knuckles first.
Discussion Starter · #8 ·
I did it I did a little yesterday: lid, super charger, spark plugs, wires and coils. Took about 2 hours. Today I removed the heads and exhaust manifold. Little work to getting the heads off though. Only took about 4 hours though. Pretty straight forward
A V specific heads cam diy would be nice.
Guess I'll have to charge up the camera lol. I would guess head cam would take me a good 8 or 10 hours depending how the block cleans up time wise. I've done a bunch of heads cam swaps though, and have been a mechanic for about 20 years now. Plus I've had my bumper off and all that junk a couple times now, which I think is the difference in time doing these vs like a c5 or something. They crammed a lot of shit up there.
I've also been pondering the idea of painting some of the accessories and maybe the timing cover.. I can't stand the look of old aluminum, and I'm not about to polish all of that shit
I followed the Camaro forum breakdown. I'm not a mechanic, so it took a bit of time....34hrs or thereabouts. Bagged and tagged bolts and cleaned parts as I went in my garage on some ramps.
1 - 13 of 13 Posts
