I finished a full build on my car about 2 months ago. Tuning was done about a month ago and I've been enjoying the power for about a month, doing 2-3 WOT pulls to about 130mph per week.
Last night at WOT, 7000rpm in 3rd, the car let out a ton of blue smoke. Pulled over, looked under the car and the whole undercarriage of the car was covered in oil. The car did not lose oil pressure, and was still running well with no issues other than the oil.
Checked the oil and it was 3/4 on the dipstick. I'm guessing the car dumped about 1/2qt in about 15s.
Started the car back up and no oil was leaking. Kept it under vacuum and limped it home, stopping regularly to check for more oil leaking under car and the oil level. It was fine. No blue smoke on cruise or decel. I didn't try putting the engine under load.
I have to start pulling stuff to really see where it is coming from. Around the valve covers is dry. The front top half of the engine is dry. There is significant oil on the front bottom of engine, about 1/2 up the side of the the engine towards the back, the transmission is coated, headers/xpipe, and rear end all have a decent amount of oil on them.
Without starting to tear into it, it looks like the front crank seal. Would this much oil come out under boost? The fact that it didn't continue to pour oil when driving it home under vacuum, it is not leaking at idle and has good oil pressure leads me to believe the leak isn't from a pressurize oil source like an oil cooler line.
Car is making 15.5psi on ported MMS260 heads and 2.5 cam. I was debating running a mighty mouse wild setup, but currently only have the Moroso catch can on the car, which maybe allowed too much crank pressure? Next step is to pull the damper and check the seal, but thought I'd ask if anyone has had something similar happen and if the font seal makes sense. Anything else I should be looking at?
I'll also be doing a compression test.
Finally, is there enough room in there to pull the damper without removing the rad shroud/fans?
Thanks!
Thanks!
