Pierburg CWA series available from several vendors here.
Thanks for the input, Pierburg seems to be the pump of choice. Although they do have a couple different options (CWA100, CWA150, CWA400) all with different flow rates. Anyone suggested more than another for the larger C&R H/E?Pierburg CWA series available from several vendors here.
Awesome! Thanks again for the photos and recommendation. Will definitely be curious to see how the new Brick does and will be watching for the post on that.I purchased the Peirburg CWA 100 pump along with the C&R HX. The 100 is completely plug and play, and bolts up to the stock location which was important to me. Inlet and outlets are correctly oriented. I can't recall if the other ones are 100% P&P but you'd have to check.
The pump works phenomenally in my application, and I'm really excited to see how the C&R brick improves efficiency this year. (the car is NOT reassembled jsut yet 😞)
