1 - 8 of 8 Posts
Does anyone have a diagram or picture of the ground locations. I know I have 3 on the passenger side and 1 on the driver. but im just trying to confirm they are the right spots unless it doesnt really matter. I know on the driver side I have the upper bracket of some sort that goes into the corner of the head. I like doing things right and cant seem to find a picture of it or diagram of where to put the grounds.
Found lots of threads on it but nothing I can look at for my simple mind. Comments? Cheers!
Tjt.. this is how I have/ remember mine on passenger side
Discussion Starter #4
Excellent, thank you very much!
Not sure if the same on stock heads, but it DID matter where they went on my Mamo MMS260 heads. The factory bolts would bottom out on some of the holes and not others. Had to make sure I used the holes where they did not bottom out. Either that or cut down the bolts.
1 - 8 of 8 Posts
