There are some people who do and think its fine and others that would want a higher stall speed. This is why we recommend 2.5 for stock converter guys just to be safe. It depends on you and your driving habits and where you live
One of my customers i was talking with recently had told me there is a chance of burning up the trans pump by running to small of a stall. This info made me rethink rather or not if I should get a higher stall converter now before I put it all back togetherThere are some people who do and think its fine and others that would want a higher stall speed. This is why we recommend 2.5 for stock converter guys just to be safe. It depends on you and your driving habits and where you live
What is the drivability of stock vs having a stall beside the pushing through the brakes.I dont think there is any concern besides some idle and drivability annoyance that as I said bothers some more then others.
Sweet yea let me know!Fwiw- I’m running a 3000 stall Circle D with an equivalent cam. Should have the car back on the road tomorrow and will let you know.
How is it so farFwiw- I’m running a 3000 stall Circle D with an equivalent cam. Should have the car back on the road tomorrow and will let you know.
I wouldn’t call that an equivalent cam since the lobes, duration, lift at both lobe and valve, LSA etc are all different then the OP.Well the shop got the push rod / lifter preload wrong on 3 holes, so misfired. Should have it sorted by Wednesday. More to come…
BTW- I’m running the 1.8 rocker for gross lift of .675”. 236/249 duration
Just a bit of info which might help you, or others.Well the shop got the push rod / lifter preload wrong on 3 holes, so misfired. Should have it sorted by Wednesday. More to come…
Here you go, copied this just for you..lolWhat is the drivability of stock vs having a stall beside the pushing through the brakes.
Stock stall will have no power till a certain power range?
High stall will the tires break loose easily?
Dang I'm about to measure mine 😬Well the shop got the push rod / lifter preload wrong on 3 holes, so misfired. Should have it sorted by Wednesday. More to come…
So the brake stall will act like normal. But the car won't move until the higher flash stall has been reached? Causing a delayed take of in part throttle driving?Here you go, copied this just for you..lol
Flash stall refers to the amount of rpm observed when you initially hit the throttle with the vehicle under load, the opposite of sitting up against the converter while matting the foot brake during the brake stall test. This initial hard acceleration can cause the converter to flash at an rpm higher than its brake stall speed.
It's a bit confusing, but the paragraph above pretty much describes the term 'Stall'.
With a Trans-Brake and a Glide, your pretty much just dealing with what I call 'Flash Stall' at peak torque. This eliminates the issue of stall associated with the brake pedal.
The converters for these cars are much tighter then something for a 3 or 4 speed. If you flash ot it will jump up in rpm but normal driving is close to stockSo the brake stall will act like normal. But the car won't move until the higher flash stall has been reached? Causing a delayed take of in part throttle driving?
Nope, don’t think so. I personally think they can adjust preload a little better. I think they were trying to keep it at exactly.030” ( no plus or minus)Dang I'm about to measure mine 😬
Did it mess anything up
My bad. I was under the impression OP was looking at cams that put you in the 700+ range. Looking back I do have a totally different set up-way more lift and duration. Circle D built the trans and recommended, along with Mamo not to go more that 3000 stall. Just slightly more than stock which is ~2000 because it will idle a little higher than stock.I wouldn’t call that an equivalent cam since the lobes, duration, lift at both lobe and valve, LSA etc are all different then the OP.
Regardless of that a 3000 stall speed in 245-265mm will cover it but how it drives has other factors depending on converter options. You do not have to have a loose driving converter to allow a reasonable idle rpm for cams a little larger then what a stock converter works best with. Power still comes in at low rpm so you don't need to setup it up like you would with an NA build or Centrifugal blower.
