1 - 20 of 42 Posts
Banned
Just bought a 2012 CTS V with 67,000 miles . Had it delivered from out of state and arrived with a full tank of gas, well I parked it in my garage and I have this raw gas odor from the car. I was wondering if anyone may have an idea what it may be?
Does it have any mods? Exhaust work? Notice any new stains on garage floor where car was parked?
Could be a leaky fuel hat connection. Search for Fuel Hat Leak Repair, there's a few that have documented the process.
Leaky fuel pump hat, get ready to have some fun. Look under the passenger rear and see if the side of the tank is wet. You can do it yourself for about $100, but it's a mid-level repair skill wise. There is a fantastic write up to follow though.
Sent from my Pixel 3a using Tapatalk
V Coupe Pedal car
Yes. Fuel hat repair.
I wouldn't park it in the garage........
V Coupe Pedal car
Banned
Discussion Starter · #10 ·
Looked under the car and that is exactly what my tank looks like-wet with gas
V Coupe Pedal car
BINGO! You have the Fuel Hat Leak issue!
While it's aggravating that any car has a 'known issue' of any kind, it IS helpful that its well documented rather than your having some never-seen problem. For this, the info and parts are available.
Banned
Discussion Starter · #12 ·
its going to the dealer Monday, can only imagine what that’s gonna cost
The dealer will quote you replacing the fuel pump (over $1,000 just the part) and the labor will involve dropping the rear cradle just to drop the tank. Probably a $2500 job you can do yourself for $100 and some patience.
I take it you got yours all sorted out? Mine is still dry and smelling right. Thank God for Silver Surfer, owe that man a beer.
V Coupe Pedal car
I have not yet done mine. I am amassing quite a pile of boxes and a long list of work to do, once I get back home!!
V Coupe Pedal car
This is one of those jobs that has a DIY work-around method that lets a guy do this task for $100 in parts and basically a Saturday. The method involves cutting a hole in the car's floor for access, not a task for the faint of heart, or for one lacking certain tools.
The dealer wll not do the job that way, they will remove the fuel tank AND the rear suspension cradle to do so. They will not repair the leaking fitting in the hat; rather they will sell you a compete fuel pump carrier module. It will be pretty painful, I'm sure.
It's possible though that you might find an independent shop that will save you a chunk of money.
"a Saturday"... You're funny!!!
It's certainly possible, but not my experience. Mostly my own doing TBH.
@RCJ if it was me, I'd have the dealer drop it but have them put in @adam112 's hat.
Reactions: random84
Can you cut the section from under the rear seat with the tank in place? Albeit risky!
Yes, but with the proper tools and methods in the other post linked above.
Reactions: jcs003
1 - 20 of 42 Posts
