1 - 7 of 7 Posts
I’m having an issue and I’m trying to solve it with the help of the community. I recently had a relay blow out in my Fuse Box (under hood location)
Not only did the relay burn out so did the Fuse Box as well. Upon trying to find a new one using Part Number 20836161 looks to be discontinued or just not available. Could I use I later model V2 Fuse Box with out any issues?
Shows to be the same box only difference is HID versus non-HID. Take a picture of yours and match it up. I had hell with mine being loose. The bolts that hold it on only pull it so much. Mine was loose and that would not let the fuel control module to turn on the second fuel pump. Took lots of diagnosis to find it.
I ran into this issue too when I fried my fusebox. I was lucky and found a new one at a dealership a few cities away.
My local dealership can do an online search to check if other dealerships have a certain part.
Reactions: loweredd
1 - 7 of 7 Posts
