Request tuner feedback. My advance thank you...
At 5100rpm, 15.8lbs boost, 65psi fuel, 68% injector duty, 51lbs injector flow, 100% pump DC.
Stock PMW system, 1050x injectors (characterized), DW300c pumps w/ 80-90prv, boost modulation cut disabled. 92 pump boosted with 10% toluene.
My calculations take into account a 5psi drop in rail fuel pressure at WOT.
Based on the above, pressure delta minus 5psi rail pressure drop, I figure to increase the injector duty cycle up to 80% by adding 20% to the flow rates in my Flow vs Pressure Delta table. I do not want to exceed 80% injector duty cycle at any time.
I've observed the Flow vs Press Delta table is very accurate at WOT. My goal is to maintain a steady 1 bar delta at WOT at any given time.
I modified the FPCM fuel pump percentage in the OL Fuel Press DC table to ramp the pumps 100% at 131lbs Instantaneous fuel pressure and above. I set Regulation Pressure to 65psi max at 131lbs Instantaneous and above for voltages between 12v-18v. Added 20% to the Flow Rate tables (Engine and FPCM) from 41.8 Pressure Delta to get the 80% at 65psi fuel pressure I hope to achieve.
Side note:
Trial/error/observation, with a 80-90prv installed in a stock PWM system, fuel pressures jump and remain at 'pump' unfriendly elevated pressure levels during normal (non-boost) driving conditions. I have overcome this by setting all max fuel pressure tables to 50psi, both in the Engine and FPCM. Note, despite the 50psi max set values, these are superseded above 5000rpm.
My observation currently leads me to believe that the Flow/Press table in the FPCM does little or nothing, limited to 63.5lbs compared to the Engine Flow/Press table 127lbs. The upper values will never be realized any how.
My goal is to remain at a constant 1 bar at WOT, of course after calculating for the delta, maximize injector flow and duty cycle to 80% potential at a 100% pump flow.
DW does not recommend exceeding 16v on the 300c pumps or running high pressure needlessly for extended periods. Don't think the V will ever see 16v, but I have never actually hooked-up a meter?
Again, thank you for feedback...
I also want to add the following while on the subject for those less experienced with fueling as a confidence building side note, and wanting to remain on pump gas.
I have learned based on personal experience, the stock PMW system using pump gas (92 minimum) is an outstanding OEM setup for those with plans not exceeding the 800hp range at the crank. This does require installing larger capacity pumps, injectors, and PRV. Very important to properly tune the Engine and FPCM afterwards. I personally run a bit rich at WOT to accommodate the rear #7 and #8 cylinders. The only real pain is accessing the fuel pump assembly, need to be extremely careful not to damage fuel lines when cutting away the sheet metal, clearance is around 0.125"-0.250"
