There aren’t any pumps on the driver’s side.
OK that is what I thought. Will do the passenger side first and hope that is the problem side. Hopefully won't have to get into both. Thanks for the infoI don't think the pre fabricated patch panel that is typically used on the passenger side will work well on the drivers side. It really needs to be a mirror image of what it is to work there.
@Sudderth thanks for the tips! Gathering the parts to tackle this. Ordered similar plate from another company (can't remember at the moment). Also ordered the upgraded hat from ALM that addresses the fuel line connection leak. Don't have that problem currently, but figured since I'm in there already, might as well take a few extra steps and change it out.![]()
Products
weaponxmotorsports.com
they supposedly have the cover plate. It does not fit exactly but it beats making your own. Just be careful cutting the hole so you don't cut the wires, hoses or drill a hole in the gas tank. My hose was messed up so I removed the whole thing and went down to a hose store and had a braided stainless steel hose made with the proper end and used two fuel injector hose clamps on the tank side. I took the old one down as a pattern for the guy to make the new one fit first time. Put your o-ring in the sun so it dries out so it will fit. If the o-ring is wet with fuel it expands and makes it a pain to get the fuel lid to seal. Oh, get a fuel pump ring removal tool as the ring that holds the assembly in place is difficult to remove. That Lucas gun oil in a spray can works great to get the ring to loosen up. If you need to jar it loose get a brass hammer so you don't make sparks... Have a friend do fire watch with a fire extinguisher.
