Fscm fuse burnt out
776 Views 3 Replies 4 Participants Last post by  RocketSled
Anyone know what color wire that is ran to the rear fuse 21 (fscm)? Mine burnt somehow and it messed the hole up when I took it out. Would like to put an online fuse in until I get a new block but not sure which wire it is.
Gas Electrical wiring Electrical supply Machine Electric blue
1 - 4 of 4 Posts
Do you know how to use a DVM?
Ohm it out.
Or pull the block out and trace the wire from the fuse.
But first you need to figure out why the fuse burned out. Otherwise, any new fuse you install (by whatever method) will also burn out, unless you make it a really big fuse in which case the wires or whatever the fuse is sending power to will burn out instead.
Reactions: 3
1 - 4 of 4 Posts
