Many years now I’ve searched and searched for this mod and how to do it. With the help of the guys here it is completed. Maybe someone could use this info if they want to do this mod.
Special thanks to loweredd, Blades1_99, SimplyDreamin, CamCamaro1991 and RocketSled for y’all’s help and motivation.
I started by removing my headlights. If you‘re unaware of how to do that, look here
www.ctsvowners.com
Once you get those out, you’ll take off the top cover
View attachment 154042 View attachment 154043
The top bulb is the turn signal, the one below is your DRLs. You might as well throw in some LED bulbs there (5201,5202 6000k bright white) too. No resistors necessary for DRLs
Removing these bulbs wasn’t exactly easy due to lack of hand room, so I took a pair of long curved needle nose pliers and twisted counter clockwise. It becomes loose and you can pull it right out.
you then pinch and pull the bulb out.
That bulb has 2 black wires coming from it that need a resistor in order to prevent hyper flashing. I bought mine on Amazon via this link
https://www.amazon.com/Resistors-Signal-License-Warning-Cancellor/dp/B004EDF8HY
You have to strip about 1/2 inch of the 2 black wires to attach the resistors. A good wire stripper really helps, but you can use a blade if need be. Just be very careful not to cut any wires.
Before I connected the bulb wires to the resistors I took some 3M double sided tape and mounted the resistors inside the housing just below the bulb. There’s a small flat space there just perfect for it to sit.
View attachment 154050 View attachment 154051
I then wrapped the resistor wires around the spliced area, soldered them together, then wrapped with ADHESIVE Heat shrink. I didn’t take any pics of the wrapped heat shrink, but prior to that I had used electrical tape and some zip ties. See pic
Either way will work, but I suggest using the adhesive heat shrink.
When putting the LED bulbs into the socket, I used the long needle nose pliers to twist it in. Just don’t twist too hard.
I plugged both lights in, tested, then reinstalled both headlights.
Now, no hyper flashing and the turn signals are crisp and bright!
Only 2 companies make LED bulb 12272 as of now. Our cars have been out many years now and I just don’t see anyone else making any other quality 12272 bulbs anytime soon.
iJDMToy and Alla both on Amazon or through Google
I actually found another company on Amazon but wouldn’t waste my time with them. Low lumens and look cheap.
I’ve said this before, but why Cadillac put those incandescent bulbs up front I’ll never know. What I do know is LED turn signals are the shit!
Good luck
Blacked Out Headlight Mod....
Thought I would put document my adventure in blacking out the headlight housing. It requires heating the headlight in the oven and you run the risk of cracking the lens. This was put together to show the process I went through and do no take responsibility if you damage your headlight doing...
Good luck
