1 - 7 of 7 Posts
Discussion Starter · #2 · (Edited)
Found it while installing a catch can. Catch can IN was ran to the valley covor, out was ran to SC, hope it's right. Ran 3/8 hoses should they be clamped at the motor?
Mine isn’t capped, I have a brown foam over that port. Dirty side of can to valley plate, clean side to the blower
Hose routing is right, as long as the hoses are good and tight no need for clamps technically, most do use small work gear clamps as extra precaution
Discussion Starter · #6 ·
Dammit tomorrow I may have to make another catch can bracket. I don't think the hose has enough slack for motor vibration. It's mounted next to the air box. May have to add 1 1/2' to the bracket for hose flex.
On second though I should be able to get away with cutting the wire ties that I use to bind them to the other hoses.
1 - 7 of 7 Posts
