I installed mine with very minimal “fabrication” work. Maybe find a new shop?
I concur.Maybe find a new shop?
I doubt you are going to get any support from a company like Fluidyne because their product spans many applications. As stated earlier, I installed mine with no instructions because I obtained mine used. The shop should be able to figure it out by looking at the mounting tabs and hose locations.Hi all, I have a Fluidyne FHP35-CTSVJX heat exchanger going in and the shop is having trouble with the install. They have attempted to contact Fluidyne regarding the issue with no luck. Has anyone here been able to get help from them with tech support? The shop is trying to get some answers on fitment as they are having trouble getting the heat exchanger installed.
Also, if anyone has any info on the install of their latest 5-Row 3-pass heat exchanger that would be great.
Thanks!
THIS^^I installed mine with no instructions because I obtained mine used. The shop should be able to figure it out by looking at the mounting tabs and hose locations.
