Are you running a higher percentage of ethanol now or is it just the difference in EQ ratio from gas to ethanol making the difference?
Running the same 10% pump gas, my trims show a bit rich now?Are you running a higher percentage of ethanol now or is it just the difference in EQ ratio from gas to ethanol making the difference?
Thanks, forgot about the PE/LTFT relationship consideration. I'm keeping the stock 4000rpm max SD range of operation.LTFT i would keep off for yours unless ur worried about the OL fueling over time, but the STFT do quite a good job on there own but they dont influence PE, keep in mine ur always using the SD u cant turn that off like the MAF, SD is always in the background doing its thing just with more or less sway based on settings but always there when its needed, not sure on the fuel pump side
try the gear values in the final min airflow table lower a little, same with the torque follower it may have too high value in the gear rows, can be a tricky one to lower sometimes working out what tables work when in the manualsThanks, forgot about the PE/LTFT relationship consideration. I'm keeping the stock 4000rpm max SD range of operation.
I agree SD operating in the background regardless, not able to completely disable.
One more item, when approaching a stop light I sometimes throw the shifter into neutral and coast to stop. I have a consistently high 1100rpm rev in neutral that will not reduce until speed is zero. Once at zero, the idle adjusts down to my pre-set idle. Any suggestion to get the rpms to lower while coasting in neutral? ty
I tried, but it did not seem to make a difference. In gear coming to a stop I'm at 1000rpm idle, coasting in neutral 1200rpm until at zero 'stop' speed, then down to pre-set 750rpm idle.try the gear values in the final min airflow table lower a little, same with the torque follower it may have too high value in the gear rows, can be a tricky one to lower sometimes working out what tables work when in the manuals
Thank you for such an informative response. The information you share is no doubt going to keep my mind occupied at its full potential, I'm still translating! (haha)ok yea it can be tricky as i dont think we have the direct tables found in the ecu to adjust it so have to find other ways, what u can try is the area scaler ''max percent'' lower that say .5% at a time see if it helps or if not then try the percent max brake, its one of those will allow that much more TB area from idle its like a hard limit, with the manual it can be tricky when ur in neutral but rolling it is different to clutch in rolling, the brake percent may be when ur clutch in and on the brakes stopped and the percent max when ur neutral and maby rolling u will just have to test,
if that dosnt do much the max fail thats at 200 u can lower that but that one is a overall hard stop so what i usually do is lower that one so i still get commanded winter cold start rpm and it will cap it from going above that, but if u go too low on that one it will limit the cold start TB opening, if u get the max fail and those percent max/brake all setup right the idle should be kept within those barriers and u then use the idle controls to control it within there, also the ''min rpm ref'' u have set to 750 just make that 600 so its lower then your commanded idle as that one its like a limit for idle corrections so if u go below it it wont correct the idle,
also see what your idle spark is at then in neutral and rolling see if its in the idle table or mains spark table or coastdown spark table and adjust the spark lower if its in the coastdown table can help, if its in the main spark table then lower it also but if its in the stationary idle rpm/grams range then always leave about 10 deg higher spark in the main table then in the idle spark table so it gives room for the idle spark corrections to add spark if it has too, can also look at the adaptive coastdown spark table and take some spark out there in a constant value if it cant be done in the other tables cos its setup right for normal idle, staying constant will stop it from surging if its not needed to correct for something but just lower spark,
also i havnt played with them at all myself as i dont have them in my ecu but there are some baro/torque related tables to do with idle and they can help but have to be adjusted correctly could be worth looking that up on hptforum if the above dosnt get it right
bit to play with see how u go![]()
Still got the 2/10s fuel pump pressure drop at consistently the same location. I went back into editor and checked the MAF calibration, there was a slight step in about five consecutive cells, not anything that appeared too noteworthy. If I recall the sputter occurs when I blast threw those cells aggressively? I interpolated that range of cells, so hoping the issue is solved. Just wondering your experience with slight steps in the MAF curve when quickly accelerating vs a more gradual acceleration threw areas that are slightly less than smooth?LTFT i would keep off for yours unless ur worried about the OL fueling over time, but the STFT do quite a good job on there own but they dont influence PE, keep in mine ur always using the SD u cant turn that off like the MAF, SD is always in the background doing its thing just with more or less sway based on settings but always there when its needed, not sure on the fuel pump side
Here is a screen shot of the fuel pressure dip, I have the channel values visible in this image, I think I am pretty dead-on with the dynamic?always log maf airflow, ve airflow (if u have it) and dynamic airflow, the maf should be a smooth table with sometimes gradual shifts as it follows the airflow thru the motor, if ur using the throttle going thru the range faster and its different then id look at the VVE/VE or even transients, look at the MAF g/s and dynamic airflow g/s if at that point the maf is say 400g/s and dynamic is 350g/s then thats showing its not using the maf at that point and u prob have to add some to the VVE/VE, or its a tip in event and the transients need adjusting a little, if ur blended then the greater/faster the throttle movement the more sway it will have toward the VVE/VE
It's only at this exact point I have zero pump, like 2/10s. But I made a slight MAF adjustment, so maybe it's fine now, just haven't driven the car since the change.im not too sure on the fuel pressure drop side, i dont have a fpcm to play with so have only done little with them, your injector delta should be accounting for it tho so it shouldnt be causing any difference, but id think there should be an adjustment for it somewhere might be in a low mode or something ?
I wanted to share an observation.ok yea it can be tricky as i dont think we have the direct tables found in the ecu to adjust it so have to find other ways, what u can try is the area scaler ''max percent'' lower that say .5% at a time see if it helps or if not then try the percent max brake, its one of those will allow that much more TB area from idle its like a hard limit, with the manual it can be tricky when ur in neutral but rolling it is different to clutch in rolling, the brake percent may be when ur clutch in and on the brakes stopped and the percent max when ur neutral and maby rolling u will just have to test,
