Fabtech heat exchanger
1157 Views 2 Replies 2 Participants Last post by  OscarT
Installed heat exchanger but noticed powersteering and coolant lines are touching the back of the heat exchanger, anybody that installed one have a solution for this or will it be ok leaving it like that?
1 - 3 of 3 Posts
I left out the screw and used zip ties to pull the lines away from the HX just a little. Make sure not to pull to hard with the ties and kink the lines.
Ok thanks, I was thinking taking off the lines and shortening them but that would be too messy. I’ll do the zip ties instead.
1 - 3 of 3 Posts
