Exhaust rattle
570 Views 7 Replies 2 Participants Last post by  Lt1z
Noticed a rattle that comes/goes right when I lightly get on the throttle. Tracked it down to the rear muffler area so not sure if that’s know to fail or I have a heat shield touching something. Will dig in more today but wanted to know if anyone else had issues with exhaust rattling.
Thanks!
1 - 8 of 8 Posts
Thanks!
It could be the valves
Thanks for the input Matt!
I’ll see if i notice it with valves closed, but if that’s the case looks like I need another oem muffler. You have any used ones available?
No we don’t. 99% of the time I recommend keeping them as part of the build rather then dropping $2200 on aftermarket axle backs most find too loud after mods.
That’s what I figured, I totally agree.
Once the exhaust is hot, it rattles in either mode juts less audible when closed. Looks like I need a new muff…
Have to determine the source of the rattle
For sure. Just banged around with rubber mallet and 99% sure I duplicated rattle on driver side near valve.
New muffler is pricey af and used are sus so not sure what I wanna do.
Also how tf does it connect to mid pipe near axle? Looks like slip fit
Yes assuming you have ARH
1 - 8 of 8 Posts
