just log the MAP sensor and with key on engine off see what kpa it reads (about 102kpa depending on altitude) then when ur driving anything over that kpa is boost
I just did a log of everything im not seeing the map on there thojust log the MAP sensor and with key on engine off see what kpa it reads (about 102kpa depending on altitude) then when ur driving anything over that kpa is boost
11Coupe "modified a bit upper injectors airaid e85 catch can hx" - wrecked - engine trans computer pulled. Dropped into a 09sedan.any fault codes ? what was done between in being good and now bad ?
Found it in hptuners finally, While driving, it is staying at 100kpa the whole time it drops slightly 98 at 3k rpmjust log the MAP sensor and with key on engine off see what kpa it reads (about 102kpa depending on altitude) then when ur driving anything over that kpa is boost
