Was driving to work today and got Engine Hot AC Off message and gauge was all the way on the low side. Lucky I wasn't far from home so I took her home and drove the DD to work.
Checked under the hood and nothing was overheating or hot and fluid was normal level.
I was logging with HP Tuners and temp was normal.
Turned off the car when I got home and when I went to restart all gauges did the normal sweep EXCEPT the Temp gauge and it didn't move.
I didn't get a chance to check for codes.
If the Temp Sensor was bad how would I still get a reading from HP Tuners and would a bad sensor cause the gauge not to do the startup sweep?
