I read a lot. But my first fiasco, maybe.
2005 T56 120,000k a bit sloppy. Took too south Florida A+ shop that only does manuals. $1700 new synchros, steel shift fork. Couple bearings and input shaft.
Bolting got to about an inch away. Used guide bolts. Lined ‘er up and inched in and torqued
Notice output triangle very stiff. But two hands could move.
hooked up and fired up with driveline attached after clutch bleed.
Ran for 5 minutes and kinda stalled. Tried to start and kind of bound.
Thought it thru. Removed trans. Called shop. Turns out input shaft is 1/2” too long. Meant for GTO orC06. Not V.
Crossing fingers. Has anyone had this happen and any engine internal / tranny damage from spring loading the crank about 7/16” ?? (New ls7 flywheel/clutch)
