1 - 20 of 20 Posts
The radio antenna receiver on the roof of my wife's Ford Flex is stripped out (the antenna screws into it) and I can't get a good bite for the antenna to hold. I've tapped threads into it (twice) but now there's really not enough in there for the antenna threads to bite. I'd love to just use some JB Weld for a permanent hold, but I'm afraid it will inhibit the radio signal. Suggestions?
Yeah, that's what I'm finding - super expensive to use silver.
Also finding this at a much more reasonable cost, but certainly the lesser option.
Think JB Weld is a hard no? Or would there still be enough direct contact between the antenna and the housing?
Sent from my Pixel 3a using Tapatalk
JB Weld isn't conductive, I thought that was a pre-requisite.
Instead of tapping holes in set epoxy, why not use it to hold a threaded conductive insert?
Discussion Starter #5
Not sure I follow your last statement.
I do understand that JB Weld is not conductive, curious if a small amount would hold the antenna in the socket but the connection still predominantly be metal to metal.
As a temporary solution, I've stripped a small piece of strand wire, flattened it out, and inserted it in the hole while threading in the antenna. It has a decent hold but don't think it'll survive a car wash.
Is there enough material left to helicoil it? That would definitely be conductive.
Discussion Starter #7
I don't believe so.
I would like to see a pic.
how about attaching a nut with some JB weld or other product , this way it tightens and still makes contact with the roof
Discussion Starter #10
Pics. Think this will work fine, but a permanent solution would be nice.
146747
146748
146749
146750
Just spitballing some ideas here:
1. use your wire trick there to get a solid electrical connection, but then use in addition some jbweld on the black area just outside of the hole. Like where the bottom cupped area of the antenna is, so the jb is hidden underneath.
2. Use some soldering filler wire, melt into a liquid and dump into the hole. Then thread in antenna and let harden.
Reactions: SilverSedan
Reactions: 04chase
Discussion Starter #14
Have to drop the headliner to change the base.
probably just the rear part, its not bad to do ive replaced /painted a bunch of them in my lifetime . are you sure there isnt some kind of access panel on the inside?
Discussion Starter #16
I read the procedure on a Flex forum. While it would be preferable to have a new base, that will be a last resort for me.
Just put some epoxy in the hole and screw the insert in. Stripped doesn't mean there is no contact, there'll still be plenty of metal on metal contact, and you only need a tiny little point of contact for the antenna to work. If you want to maximize contact, wrap some aluminum foil around the insert threads before you screw it in... This is an antenna, the electrical current is measured in µAmps, a big contact area isn't required. It'd probably work just fine with the tiniest, infinitesimally small point of contact.
Did you try no antenna ? The radio part of it may actually be in one of the windshields
Discussion Starter #19
Reception is shit without it.
lol who uses the radio ?
id helicoil that with some thread locking
1 - 20 of 20 Posts
