You need to be a lot more specific about location (lots of pics!), color of wires and how many at the connector. Stick a DVM across the connections and see if voltage appears, and if so how much when car is running.
Ok sorry about that, thanks for , the car isnt running , no fire anywhere , no Start nothing at all, i got all the Wiring diagram and cant find anyrhing wro g exept that connector unplugged... Its located on front engine at right Side very close too the fuse boxe... There are 2 wire , black one and purple (Much bigger than others connection. The sealed its red sameting that the alternative... Allô the others connector are purple are Blue.. .. :/ need too know thanksYou need to be a lot more specific about location (lots of pics!), color of wires and how many at the connector. Stick a DVM across the connections and see if voltage appears, and if so how much when car is running.
