I have a 2011 V, 137k miles. ABS light, TC light, stabilitrak off every time I start the car up. I have checked multiple grounds, tested both ground cables connecting the EBCM as well, no issues. It seems like I will have to replace the EBCM but I don't have the capability to program a new one so I'm avoiding it until absolutely necessary. Just curious if anyone else has had a similar issue. I've searched the forums but haven't found anyone with the same code (c0110), I've seen similar issues as far as the dash lights but all seemed to be a ground issue. any info helps, Thanks!
EDIT: I managed to get the new ECBM installed and working tonight, my service lights are gone! I plan to write up everything I did in the process in the next couple of days and hopefully can help some of you guys out!
