1 - 12 of 12 Posts
If you're shooting for big power/boost on the LT4 and want to run full e85 without being heavily dependent on meth, you'll want to add secondary port injection. I needed it with my build.
Early on I tried the LPE big bore high side fuel pump, cam with +32% fuel lobe and FIC high flow injectors. Even that setup wasn't enough to run full E without meth. I'm glad I went port injection as I now have fuel for days and don't need the meth. Katech has a belt driven pump setup that should support good power with full e but I don't think many have tried that setup yet. Port injection is the proven setup and there are several nice kits out there.
Unless you want to run full e85 on an all stock car it will need some big help depending .
A whp and budget is what need to be identified first
Sent from my SM-G981U using Tapatalk
Secondary port injection on a LT4/5 engine with E/85 just gets me all tight in the pants.
I don't even own a V3 and I'm about to google what it takes to setup a secondary port injection kit on these engines.
Anyone here on straight E85?
What are your supporting mods
Thanks
I run E as much as possible. I have DW300 fuels pumps intank. The DSS EXTERNAL fuel pump And FIC 1300 injectors. That’s all I have and no issues over 2 years now.
Reactions: MYV
I wana go full E without having to use meth
Meph is fine. Serious - I'ph been uphsing for yearphs whiff no ill ephects.
LT4 vs LSA is different for e85, especially at high hp levels. When I had my V2, I thought $1k for injectors was crazy, haha.
1 - 12 of 12 Posts
