Likely because it isn’t something that would be used on a stock cam car but I believe it should work if populated with the correct values as long as the MAF is enabled. SD will disable misfire detection.
Likely because it isn’t something that would be used on a stock cam car but I believe it should work if populated with the correct values as long as the MAF is enabled. SD will disable misfire detection.It appears that the 2 Bar OS has all
Engine Diag/Misfire/ values set to 32,768 max without edit option. What is the reason for this as compared to a non-2 bar OS for CTS-V2?
I am running the 2 Bar blended. All the values are greyed-out? Meaning it will not allow me to make changes. I never knew that SD disabled misfire, interesting.Likely because it isn’t something that would be used on a stock cam car but I believe it should work if populated with the correct values as long as the MAF is enabled. SD will disable misfire detection.
I am in advance view, it's possible there may be a version difference from the time it was released. Car is running excellent, no misfires. I just was curious? Thanks for the response.Maybe a software version difference.
Either way you can always load a stock OS tune if you are chasing a misfire.
I see misfire tables on this custom OS. Maybe you are not in advanced view.
Windows 10 hereI'm still using 4.10.7 and was forced into a MPVI 2+ with Pro Features as my old Laptop died. I had to upgrade to MPVI2+ because my new Laptop has Windows 11 and the MPVI1 isn't compatible with Win 11.
Yeah, I didn't have a choice.Windows 10 here
Never thought of that, I'll definitely take a look.kittyboy- If you are on V5, are you able to see all of your DTC's? If any are greyed out that might be your issue and it may be why you can't see the misfire tables as the software is still locked out.
UPDATE: 11/27/22Never thought of that, I'll definitely take a look.
I went ahead and registered the HPT course and re-installed v.5. I figure I'll just make myself an easy target for prison life, I hear the food has improved and free health care. Maybe an opportunity to start a side-gig remote tuning. haha Just think, tuning in prison.I'm sure newer vehicles will suffer in the performance aftermarket world underground. Something to be said just keeping what I already have.
