1 - 20 of 21 Posts
11 v coupe auto
I'm happy with the curve, it just seems different from others I've seen. What does yours looks like
Rectangle Slope Plot Triangle Font
Just a comment, assuming your engine is tuned & fueled correctly.
Induction System_CFM Supply Side, versus Piston_CFM Demand Side.
When your Peak Torque RPM moves downwards, that
is a sign that your VE% has become insufficient, regarding
its ability to 'Supply' the CFM 'Demand' for your engine.
To help others to understand your graphs (as well as me..lol)
consider, putting your mods into your signature line.
And while this forum member (just below), is extremely wealthy,
and the cost of mods is 'Pocket Change' for him. . ;) :D
A good signature line to look at, would be @Blades1_99 .
Just a comment; 100% Cylinder Fill, will produce about 755 rwHP (this ranges / varies a bit), mostly due to the engines efficiency, which is directly related to the engines static compression ratio.
As you move past about 87%, of that fill, fuel, mass flow recovery,
tune, etc. all begin to rear their ugly heads.
=> (0.87 * 755) = 657 rwHP.
I normally simply call this number 660 rwHP. . . .
Take Care!
2013 White Diamond sedan A6
2013 A6 Sedan
Airaid intake w/green filter
Reinforced brick
FIC 1000 injectors
2.5/9.1 Upper/Lower pulley
Flex fuel sensor E85
DSX aux fuel pump
Track attack HX
Varimax HX pump
2" TSP long tube headers w/ 3" x-pipe no cats to stock muffler
NGK Tr7ix plugs and MSD wires
Moroso Catch can
160 Tstat
Dynojet tuned
2013 A6 Sedan
Reinforced brick
FIC 1000 injectors
DSX aux fuel pump
Track attack HX
Varimax HX pump
Moroso Catch can
160 Tstat
Dynojet tuned
And your Peak HP, at 6,330 RPM, is very close to the 660 rwHP I stated in my earlier post.
And since the engine made 646 rwHP, the equivalent engine rpm to inhale sufficient air (CFM) to make that HP, tells me that the engine inhaled the equivalent air (CFM) associated with spinning the engine to ~10,240 rpm.
So, VE% then is equal to. . .
=> (10240 / 6330)= ~162%
But Cylinder Fill, or %VE, is only at ~86%
With that pulley ratio, and because your approaching that 660 rwHP, it is
good to see your running E85, and have upgraded your HX.. (y) (y)
One comment, just to be sure you understand something very important;
When running E85, and using a 160° Thermostat, be sure you both check
your Catch Can for water, as well as change your oil frequently. . . .
Only when compared to a bushman of the Tsavo.
Reactions: Rubber Duck
But, but, but…Bushman don’t own yachts, or have multiple dwellings around the world, or slaves in their kitchen, cooking them meals 24 hours a day, as you do..🤪😜🤣
And since the engine made 646 rwHP, the equivalent engine rpm to inhale sufficient air, to make that HP, tells me that the engine inhaled the equivalent air, associated with spinning the engine to ~10,240 rpm.
So, VE% then
Thanks for the response and the heads up. What prevents the %VE from being 100%? Needs porting and or cam? Sorry I’m no engineer but trying to understand. Also why would water be potentially getting in the catch can? Gaskets breaking down?
You wrote:
"Thanks for the response and the heads up. What prevents the %VE from being 100%? Needs porting and or cam? Sorry I’m no engineer but trying to understand."
First, VE% (not %VE) is related to engine rpm, piston speed, and how well the induction system has been engineered.
That formula is. . .RPM * CID / 3456
Where a 376 CID, Spun to 6800 rpm, will inhale . . . .
=> (376 * 6800 / 3456)= 740 CFM.
Generally speaking, that would be sufficient air to support how much fwHP. . .
Here we should actually use the 'Air Standard Efficiency', or %ASE, which relates %ASE to the static compression ratio. However, because these engines have a roots blower, that tends to change many things.
And since the High-Perf Automotive Industry has standardized their calculations, by stating that it takes 1.5 CFM to generate 1.0 fwHP, we can simply use that 1.5 Number.
Also, if we take the reciprocal of 0.67, we do get the value of 1.5, if we round up. . .
So then; 740 cfm would produce ~(740 / 1.5)= 493 fwHP.
%VE is a calculation, which relates to how much more the
engines cylinders have been filled, versus what the cylinder
had been calculated to fill.
So a %VE of 120%, tells one that the cylinder was filled to 120%, of what it would take to reach 100% cylinder fill. Whereas, a value of %VE of 87%, which is very common in many high performance street / strip engines, tells one that the cylinder has been filled to 87%.
Regarding what stops an engine from producing over 100%, %VE?
Insufficient engine rpm, which results in insufficient piston speed.
If we do have sufficient engine rpm, and sufficient piston speed,
then one should then begin to look at their induction system.
But that is not the case here, as most on this forum do not shift
at a sufficiently high engine rpm. And since piston speed is a
derivative of engine rpm, the piston speed would also not sufficient
to generate a pressure differential across the intake valve.
-'supply side' of engine, must meet requirements set, by 'demand side' of engine-
And if they do shift at a sufficiently high rpm, is their induction system sufficient enough to 'Supply' enough air, to meet the Piston CFM 'Demand', which is dictated by the piston speed.
Piston CFM Demand then, must be met with a sufficient CFM Supply
You also wrote:
"Also why would water be potentially getting in the catch can? Gaskets breaking down?"
Nope, any ethanol, be it Methanol (wood) or E-85 (corn sugar) attracts water.
We recently had a thread on this forum, where I spent much time explaining all of that.
Typically, the easiest way to find a thread / topic like that, is to go to Google, and type in your question, and add CTS-V Owners Forum to the query,
So, since E85 is 85% Ethanol, it attracts water.
And that water is best trapped in a 'Catch Can', and must be emptied often, much more often than if the engine was running on Gasoline. And it is best to also change your oil and filter at 2,000 - 3,000 mile intervals with E-85.
Here's mine.
Rectangle Slope Plot Line Font
93 to E85
Thanks for the info.. :giggle:
So on 'Gasoline, essentially your in the 87% Cylinder Fill range I have spoken about.
That 87% Cylinder Fill, amounts to about, or approximately 660 HP. . . Depending!
In my opinion, that makes for a very nice performing street / strip package.
Depending on how all of the variables are managed at the track, that's a 10 Second Street Car!
Congratulations!
RD
2012 Sedan A6
Diamond pistons .010 over, stock compression
Ported heads and 5 angle valve grind
Deka 80 injectors (91 octane here, no E85 - booooo)
LS9 cam (wish I had gone with something like a gp tuning 2.5)
Pac 1218 springs
Reinforced brick, Dedicated Motorsports HX expansion tank, Pierberg pump and 3/4" lines
2.55 / 9.1 pulleys
Air raid intake with 8" green filter
Stainless works 2" headers into their 3" with cats and x pipe into stock mufflers
Water-meth, two 14gph nozzles on a progressive ramp
NGK BR7EF plugs
A bunch of other things not related to power adders. I was only able to make 3 runs on the dyno due to technical issues. Needs more timing and more VE work but she runs alright now. I'm also at 4500ft in Utah.
Rectangle Slope Plot Font Parallel
2012 Sedan A6
Pac 1218 springs
2.55 / 9.1 pulleys
NGK BR7EF plugs
You have a nice build here.
And yes, I agree, there is still more power there for you.
This is highly evident via the fact that your Peak Torque Value, is higher than is your Peak HP Value.
At Peak Engine RPM, your spinning the blower about ~23,000 RPM.
And with that pulley ratio, along with the 1.9L Roots Blower, your engine has an equivalent Internal Volume (CID) of about 414 CID.
If we take that 414 CID, and take the Square Root of 2__for 2-BAR Absolute Pressure Ratio_1-BAR of Boost, we find the following.
=> Sqrt (2)= 1.41 <= Adiabatic Density Ratio
Now, let's move forward to see if we can calculate your 'Potential fwHP'
=> (414 * 1.41 * 6500 / 3456)= 1098 'Potential CFM'.
Using the Hi-Perf Industries general rule of thumb, that it takes 1.5 CFM to generate 1.0 fwHP. . .
=> (1098 / 1.5)= 732 fwHP <= Potential fwHP.
Alternatively, we can also look at this via 'Sucks per Second', and / or 'Piston CFM Demand'.
Now, before either Raymond / @Blades1_99 , or Jesse / @random84 come in with their sexual innuendos..lol let's mathematically define what a 'Suck' is, as related to a 4-Stroke IC Engine.
If engine rpm is 6500.
The engine will see how many 'Sucks', or will inhale air and fuel (the mass charge) how many times per second.
=> (6500 / 60 / 2)= 54
And I don't think that Raymond could sustain that many 'Physical Sucks' for long, driving down the freeway, with his main heater doing the best job she can.. :D
-back on track-
PISTON SPEED & BORE AREA
Bore4.065
Stroke3.622
Bore Area12.98
Engine RPM6,500
Sucks / Second54HP
CFM703471
ALTERNATIVALY
HP
Required CFM / Supply985660
Piston CFM / Demand981657
Bore Area12.98
Equiv Calc Sucks / Sec76
Ratio Sucks / Min140.1%VE%
CFM / Piston Spd.100.4%
Ratio71.7%
And even though the above calculations, have no consideration regarding 'Boost', we once again see the HP values of ~660 show up. Too understand this, please look at the value of 140.1% VE% just above. That value is just about the same as is the Sqrt (2.0)= 1.41, which I used above.
So, here we begin to see how HI-Perf Engines should be scaled.
Good Luck!
RD
1 - 20 of 21 Posts
