1 - 13 of 13 Posts
Just installed a new set of fuel pumps to replace the AEM pumps that I've been running for a few years and am curious to know if those running this setup with the new FPR have noticed a difference in fuel pressure.
Reason I ask is because after installation, I checked fuel pressure on the scanner and saw 107psi at idle where previously it was 70. After warm up it was 100psi. I haven't made any tune adjustments yet but did take it for a short spin to see if the low fuel pressure problem was fixed and it is.
It was difficult to keep an eye on the road and the laptop so I wasn't able to see what the pressure dropped to during WOT but it pulled great to redline on 3 separate pulls but my laptop battery died before I was able to make it back to the shop to save the log file.
Just seems a bit extreme that the FPR made a 30psi difference. Anyone else see similar results?
I'll charge the laptop this evening and get a few good pulls in the morning when it's a bit cooler to see how it's behaving.
I have now heard of multiple people with 100+ cranking pressure with the DW FPR.
If you are still running returnless, you should not be seeing more than commanded pressure though. And 70 commanded at idle is high.
I'll take a look at the tune tomorrow. Been running this same tune from Pat since April 2019.
Discussion Starter #4
Desired fuel pressure was set to 448 for normal, high flow, low flow and cold engine. Adjusting them back to stock made no difference in fuel pressure - it idles at 102psi after warmup and runs at the same psi during normal driving. On a long 3rd to 4th gear pull, it drops to 73psi at 6800rpm.
Looking through the tune and comparing it to my stock file, I see that the FPCM Fitted under the Fuel System>General tab is set to NO where the stock tune has it set to YES.
Discussion Starter #5
Pat sent a quick tune revision which fixed it.
lol dang...how you were running around like that is a mystery. Yea you dont wanna turn off the fscm if you have one! Interesting stuff
Discussion Starter #7 (Edited)
Definitely crazy and I'd been running like that for 16 months. His revision changed the NO to YES in the FSCM and changed a few pressure settings.
Took it for a short spin and it held 85psi to redline through a 2nd to 4th gear pull. I'm currently only at 23% ethanol so I'll have to see how it reacts when I go back to 50%.
I am having the same issue after going from the AEM pumps to the DW300c pumps. Seeing 97 PSI at startup and 105PSI under some boost. I need to get my tuned fixed also. With that high of fuel pressure its probably running a bit rich now.
Discussion Starter #9
Pat G made a couple adjustments to my tune to fix it but I don't recall which areas he tweaked. I could run a comparison to find out.
If its not to much trouble that would be great. I could get it turned down a bit before getting it tuned again. It makes me a bit nervous seeing almost 110psi.
Discussion Starter #11
I'll check when I get to the shop tomorrow.
Discussion Starter #13
PM sent
1 - 13 of 13 Posts
