1 - 8 of 8 Posts
I attempted to install the DSX aux pump today.
I had an issue with the factory jumper line kinking when I was trying to reinstall it.
I believe it is due to my car being a coupe rather than a sedan.
The picture in the printed instructions shows what appears to be 5+" between the end of the DSX T fitting and the rear factory fuel line. Mine are only about 2" apart which is causing the kink.
I tried to talk to the folks at DSX via FM messenger and they just kept saying "read the instructions".
Anyone have any suggestions or installed this one coupe?
No difference in coupe , sedan or wagon. I would be willing to bet your missing something small that is defiantly in the instructions.
I believe I know what your talking about , flip the factory line that the t goes into and it should allow it to go on without a kink.
Pictures are beneficial here.
Sent from my SM-G981U using Tapatalk
Flipped the line as instructed . Still way closer than the pictures in the instructions.
Discussion Starter · #6 ·
So if you want to do this install the way it should be done in a perfect world this is what you need.
2 of these
2 of these
and about 10" of 6 AN hose
Zero kink, zero stupid GM clips.
he's sold a lot of these kits, I dont recall kinking lines being an issue
is it a genuine DSX kit, new or used?
1 - 8 of 8 Posts
