1 - 20 of 22 Posts
8s are the new 9s
I finally met my goal for the V.
Below is the video for my fastest pass yet.
Now I need to decide if I should keep the V or move on to a new platform.
Dude.. give us some #s...
Reactions: Screw-Rice
8s are the new 9s
Discussion Starter #5
Let me show y’all the slip.
So id say solid in the 9s..
So I'm guessing the goal was to run by yourself down the track, stop pick up the slip, take a picture with ok sign. Then yes, goal achieved . CONGRATS! Oh by the way nice 60'.
Reactions: t.j.t
8s are the new 9s
Discussion Starter #13
What’s the best way to mount a chute in a V?
8s are the new 9s
Discussion Starter #14
I am putting together a mod list because I’m sure there will be questions.
I think she’ll easily go 8.7x just by tuning the nitrous ramp. It’s still a soft hit.
Your right in the 'Pocket' regarding 60 ft, ET & MPH.
We ran an 9 lb car some years back.
Track only car!
Car was only run at NHRA Division meets or NHRA National events,
where track was professionally prepped. . . .<<= equals best track prep!
396 cid * 9)= 3,564 lbs. + 15 to 25 lbs for scale inaccuracy.
Single 850 cfm carb.
Sheet metal intake manifold.
4-Link suspension.
Car ran 1.20 to 1.26, 60 ft., most usually a 1.22, 60 ft.
Car ran consistent 9.20 to 9.28 ET, most usually a 9.22 - 9.25 ET.
Best MPH was 149.95.
So you got your 'Tuna Boat' working pretty well I would say..lol
Reactions: Guard dog
8s are the new 9s
Discussion Starter #17
Mod list:
2009 CTS V
-DynoSpeed 4.5” custom intake
-Jokerz chaos ported 1.9L blower
-2.4/10.0 pulley combo
-Southways 108mm throttle body
-NX spray bars in ZL1 lid
-ZL1 brick reinforced
-12AN ported f manifold on ZL1 lid
-Custom 9 gallon trunk mounted ice tank
-Stewart EMP pump mounted in trunk and wired into stock IC pump relay
-all -12 lines for heat exchanger circuit
-DynoSpeed extra capacity heat exchanger
-ID 1300 injectors
-fore fuel rail to prevent fuel issues to rear cylinders
-flex fuel
-fore triple pump fuel system
-single meth nozzle with windshield washer bottle converted to meth tank. Low washer fluid warning let’s you know you need more methanol
-alky control meth pump and controller
-NX maximizer nitrous controller
-NX large carbon solenoids
-Lingenfelter LNC 2000 so you can run blower only and go 9.5-9.6 or activate the nitrous and run 8s without changing tune
-6 bolt Frankenstein CNC ported trick flow castings
-Johnson lifters
-ERL 6 bolt superdeck aluminum 427
-energy suspension solid motor mounts
-2” primary Kooks stainless headers with modified collectors.
-full 3.5” dual exhaust with x pipe and 3 spin tech mufflers
-Mark Micke 4l80e trans (spray through the shifts because the trans doesn’t care)
-stock shifter modified to work with 4l80e
-DSteck trans control
-Wilwood lightweight brakes all around
-Carlyle 15” rear kit with single adjustable Penske shocks
-santhuff double adjustable coilovers in front
-weld drag pack with single bead locks in rear
-G force 9” rear center section with 3.50 gears
-G force rear axles
-all poly whiteline bushings in rear and cradle
-real carbon fiber overlay to aluminum interior trim
-carbon fiber hood
-15# nitrous bottle with -6AN line
-Front sway bar removed
-D3 heavy duty rear sway bar
Probably forgetting something
Mod list:
2009 CTS V
-ID 1300 injectors
-flex fuel
-Johnson lifters
-G force rear axles
-carbon fiber hood
I think you could spin the blower a little harder there Ray..:D
Cheers,
Bruce
Can you share how much nitrous?
Reppin Tennessee! badass Ray!
1 - 20 of 22 Posts
