Great advise. What type of RTV do you recommend?That’s why I used the RTV to glue it back on. The pegs break off and that holds the part on without coming off again. The RTV can take bring slammed each time the door closes without coming off. Just be sure to wipe the dust off before you put the blind of silicone on each spot where the plastic pegs are
broken off. If you have the panel off you can use a large book of other weight to hold it in place overnight. Otherwise, tape works when the door panel is in place.
