What you describe sure sounds like a throwout bearing. You replaced it and the noise went away for a little while. So that would seem to confirm your theory. But the replacement failed quickly. That being the case, the question is "why does this clutch assembly wreck throwout bearings?" The only way I know is if the bearing is still under load even when the clutch has been fully released. Throwout bearings are not designed to be under load continuously, they're only supposed to be loaded when you've pushed the clutch pedal down.
My guess, the clutch is not fully releasing and that's wrecking the throwout.
What does the clutch pedal throw feel like? Is the engagement point near the top or the bottom of the pedal travel?
