Hey everyone,
Looking for some opinions. I went in to get my diff looked at because I saw a splotch of diff oil on the ground when getting the car out of storage. Was about a credit card size splotch, after I saw that I checked under the car and saw the diff was wet and wiped it down. Parked the car for a few days and didn't see any new drips on the floor....so I was thinking "oh maybe a seal or something" because I had a rear axle replaced 4 years ago and the damage was listed as "driveshaft flange found separated from differential and damage to splines"
Fast forward to the first call today w/service after dropping the car off the dealer tells me I need to replace the same axle again and is causing the leak. I mentioned, can you dig into this more? It doesn't make sense to replace the same axle in under 1000 miles (I don't drive much over 4 years) to have failed again. They dig a little any tell me to replace the rear diff because its having trouble holding the axle. Does that diagnosis make sense? I'm by no means a tech but it doesn't sound far fetched to me that the diff is having issues with the shafts or something and was the original problem too...
Thanks for any advice
